SuDu LNC
Discussion dans 'Archive - Losi Comp Crawler / Night Crawler' créé par alexus, 14 Mars 2013.
  1. EGRESSor
    EGRESSor membre
    11 Janvier 2012
    did you tried the motor in the Losi?
    the 13t 5 slot arm , 7.5mm comm , 4.5mm brushes , thinn wall can
    that all creates alot of speed but no torque
    i think the low efficiency of the worm axles will kill the motor :yesd3:
  2. alexus
    alexus membre
    8 Octobre 2009
    That's a good point. Everyone seems to be concerned about my brushed motor with the lnc.
    If I try to stall the motor by locking a rear wheel under my foot the motor puts enough torque to lift the truck.
    But I need more drivetime before giving a real opinion.
    Here are the spec
    13t crawlmaster arm, high fill, epoxy balanced.
    Lathed dual fb9 magnet can
    Checkpoint endbell with lightweight hardware, copper brush and xtra firm spring ( I grinded slightly the edges of the brush)
    Ceramic bearing
    Glad you posted here Christian, one of my next mod in the plan is to modd the worm for thrust bearing.
  3. EGRESSor
    EGRESSor membre
    11 Janvier 2012
    i rebuild alot of those small comm 5 slot motors
    they were all overheated + excessive comm / brush wear without much runtime
    got the best results with narrowed standup brushes (3.2-3.6mm wide) and medium-soft springs , that creates a bit more torque and lowers the comm wear
    that motor will be great in a light ax10 based rig
    i tried thrust bearing thing in my lcc too http://www.rccrawler.com/forum/team-los ... y-lcc.html
    if i would do it again , i would do my own thrust bearings with 2 small hardened washers , ball cage of delrin or teflon and small ceramic balls like the ones known from ball diff rc´s , the ones you can buy are all pretty large
  4. alexus
    alexus membre
    8 Octobre 2009
    Thanks for the tip Christian, I got a 35t arm, I think I put it in with new brushes.
    I know you tried it, this is why I did mention it.
    Thanks for your input Christian! I like the idea of a smaller thrust bearing. The only part that could be holding me back is the homemade ball race.
  5. alexus
    alexus membre
    8 Octobre 2009
    Petite MAJ, le support moteur V2 est fini. J ai remonter le pignon fou pour pouvoir rapprocher le moteur un max de la trans. Du coup comme le support de pignon est remonter et ne genent plus j ai decider de changer de skid.
  6. alexus
    alexus membre
    8 Octobre 2009
    Presque RTR, il manque la barre de direction et j attend toujours mes cardans pour remplacer celui que j ai casser.
    Il pese 1416g comme ca pour l instant.
  7. alexus
    alexus membre
    8 Octobre 2009
    RTR :twisted:
    J ai eu l occasion de faire quelques tours de de roues en interieur. Premier bilan tres satisfaisant meme si y a quand meme des lacunes au niveau de la vitesse :roll: mais ca a part passer au brushless je vois pas quoi faire.
    1439g pret a rouler.
  8. vidou07
    vidou07 membre
    13 Février 2011
    sublime, une fois de plus :inkoi3: :inkoi3: :inkoi3: :inkoi3: :ang3: :ang3: :ang3: :ang3:
  9. Bad Rax
    Super machine :yes3: :yes3: :yeah3:
    En répartition des masses cela donne quoi??
  10. alexus
    alexus membre
    8 Octobre 2009
    Merci david :ang3: tes pieces sont en route :zunt3:
    Merci Steph :yeah3:
    La repartion je l ai pas encore calculer mais le point d equillibre est 2~3mm derriere la fixation des liens avant. Tout en sachant que le chassis est monter en 60/40 ca semble etre un bon resulat.
    Seul soucis que j ai remarquer pour l instant c est que l arriere pousse vachement et l avant roule beaucoup sur les flancs. Mais l avantage avec les nouveaux tubes ( hormis le faite qu il necessite moins de modification) c est que la chasse est reglable donc je vais pouvoir jouer la dessus et sur les mousses pour controller un peu le phenomene.
    Je sens que ca va etre fun :yesd3:
